The enclosure looks even better in the deep size! just emailed you and asked to be put on an email list so I don't miss out on the first batch.
Are you looking for the chassis or the whole amp?
New SFPP soft start board installed, cleaned up wiring, connected VU meters, it’s all working now. I changed R value in CRC to drop voltage to 28.5v. Temps now at 55C on heatsink with cover on. This is 300mm deep heatsink. When we switch to 375mm deep it should be much cooler still. Nice to see VU meters dancing when the music gets rocking.
IIRC it’s a shift register system and not i2c but then I could be wrong. There are a lot of code floating around on arduino for those shift register like RGB ledsThere are programmable RGB LEDs that need only I2C connection
