Hello Thomas,
I haven't been checking this thread until just now. Sorry about that.
Have you checked your input voltage from "the wall"? I'm using a Variac and am back to using the Mullard GZ34 tube instead of the RCA 5U4GB rectifier. The GZ34 needs 116V input to get 5V on the 300B filaments, and the 5U4GB needs 120.7 V to get the same 5V. My wall input varies from about 123V to over 124V, depending on the time of day or night. So, this is a "silent" area where most everyone suffers, and I discovered this while working on this amp. Previously, I eliminated a line conditioner and used a Furutech NTX outlet box instead. The Furutech unit wasn't cheap, but it sounded better. I already had a Staco Variac to bring up new amps, but I never used it. Finally, a friend suggested that I put the variac on the 300B, and low and behold, my 5V on the 300B filaments became possible without changing parts.
You need to work with a Variac set at the voltage to get your filament supply at around 5V for each tube. From there, you can adjust. If you live in the US, you probably have a modern input voltage above 122 V. My larger dropping resistor of 7.5K allowed the GZ34 to generate a higher voltage for the 9-pin tubes. Depending on what you want to accomplish, you might change your resistors, but maybe not if you used my 7.5K dropping resistor rather than the original dropping resistor Sunvalley used (5.6K).
Now, my GZ34 operates with higher voltages, so the nine-pin tubes sound good, but the filament supply can be dialed in exactly. I'm now looking at replacing the Staco with an adjustable variac that limits the variance to an acceptable number and goes beyond the Staco in capability.
So, to generate 5V on the 300B filaments, the GZ34 requires around 116V of wall input AC, and the 5U4GB requires about 120.7V of wall input AC. Creating that situation made a huge difference in sound quality and increased the tension of the GZ34 tube to a point where it now sounds better than the 5U4GB. Previously, the 5U4GB sounded better but was too "airy." The GZ34 now has just enough air not to sound boring. Everything now sounds up front, and singers also sound up front rather than recessed as they did with too low a voltage on the input tubes. But I changed the input tubes to make the sound quality "pop."
Just my two cents regarding making changes.
I'm now using GE 6201 tubes for 12AT7 and a pair of GE 6189W tubes for 12AU7 tubes in the 9-pin sockets. A friend sent me a stash of his 12AT7 tubes, and I already had the GE6189W here. The GE6189W was too forward before, and now it is just right. It shows that the right circuit can change our idea of what works. My former Brimar and Mullard tubes don't sound anywhere near as good, but the GE6189 paired with the 6201 is perfect. The Telfunkens and other rare NOS 12AT7 I had also didn't sound as good as now. So I can now use this amp to fine tune my speakers.
That brings the sound quality to a point where I now really love the sound quality with my Voxativ 99db Hagen speakers. I just added a pair of 12" open baffle bass per channel 4 EMS drivers) for the low end, and I am now bi-amping using the 300B on the Hagens and a good Class D amp on the bass augmentation. My idea is to take the low bass reproduction of the 300B off and place it on a high-powered Class D amp. However, the bass is no longer as fussy, so all Class D amps can sound good when used only to drive the bass augmentation speakers. I sense that the Class D amp needs a pot, but I'm reserving this decision until I go through the next 11 modules that I've ordered from Sublime. I haven't received them yet.
So will my final Class D amp be a Hypex Nilai kit, or will it require a passive pot, in which case I'll use a Khozmo amp with a built-in pot?
I just ordered 11 more modules from Sublime Acoustics to change my crossover point and limit the 30f0B amp. Right now, I have the Hagens playing full range (no crossover), and the open baffle bass is limited to playing no higher than 80Hz. With the modules, I can experiment and go down to 45Hz in 5 Hz increments. Once I have the speakers dialed in, I might go back to change this amp further, but honestly, I will probably have a custom 300B built and use the Sunvalley amp as my backup should I ever need to service the main amp.
I now have superb sound quality and transparency. My 300B tubes are Western Electric 300B, and the rectifier tube is a NOS Mullard GZ34.
Even though the voltage on my nine-pin tubes might not be perfect, I'm now fine-tuning by listening and want to get the speakers dialed in before making any other changes to this amp. Changing the input tubes made the difference I needed.
Once I'm done, I'll consider purchasing another even better 300B amp with a substantial power supply, two chassis, and very few electrolytes. It will cost a lot more, but it will be worth it.
I hope this helps,
Richard
